copier Printing Cable from pc?
  • gautammehta
    • Jun 2025
    Hello,
    Can any one tell me which cable is required If I want to print from PC to copier ?
    On My PC I have USB port. So Which cable I require to connect to copier machnie to print something from copier machine ?
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    What model copier? what options are installed?
    How many computers need to connect to it??
    • 10871087
      • Jan 2005
      • 1143
      Originally posted by gautammehta
      Hello,
      Call a tech, your in over your head!
      • gautammehta
        Hello,
        What model copier? Ex: Canon IR-5000
        what options are installed? ( Please elobarate your uestion)
        How many computers need to connect to it?? ( Only 1 laptop)
        Just to make it more clear : I want to know what is name of cable which I can use to connect my PC or Laptop ( USB port) to copier machine for taking print from copier machine.
        Gautam Mehta
        • xcopytech
          • Aug 2006
          • 1793
          First you have to know does your copier have print option.
          If your copier have print option then you have to know does it have network card or just USB port or even if it is older maybe LPT port.
          Then you will know which cable you need.
          If you want to use USB port from your PC you can only use USB cable.
          As I know there is no any special name for that cable
          • gautammehta
            Yes My Copier have print option.
            It has LPT port
            Now it is clear that I have USB port on my PC or laptop and LPT port on copier machine.
            • jim v
              • May 2008
              • 41
              Most Copiers Have A Usb Port As Well. If Your Copier Model Has One, A Standard Usb Cable Will Work.
              • costd
                • Jan 2008
                • 409
                1. Use a USB to Centronics
                2. If your laptop also has a parallel - just use a standard printer cable
                3. I am use to seeing the network/printer option as one install - if so, you could also connect it to your network.
                The above ASS-U-MEs you do have the printer option installed and not just saying it is because there is a port.
                Once you have a cable, all you need to do is download the print driver you need (url imagerunner.com)
