Question about the funtion canon copier firmware
  • hengky
    • 11
    Hii, is anybody can help give information about firmware
    I want to know about function canon copier firmware?
    Wheter the firmware just to repair hardisc error or can create the new empty hardisc?
    Thank you
    Hengky
  • teckat
    • 16083
    Re: Question about the funtion canon copier firmware
    Thank you
    Hengky
    HDD's are usually specific to it's model/ Firmware is loaded into a blank HDD that has be formatted while inside the printer with the Canon SST PROGRAM> then u can load models firmware into it---
    u can use firmware to repair an HDD error (usually need to replace HDD in most cases) or use firmware to update various versions.
    u can ghost from a working printers HDD to a blank HDD / it's a trial & error when u try that
    Canon Firmware is the operation system of the model--(no firmware =no operation )
    FUNCTION----FIRMWARE-------------------------------------------------------LOCATION-------------------------------------------------
    System
    -------------Control of the system as a whole------------------------HDD
    Language----------Display of the control panel screens-------------HDD
    RUI-------------------Display of the RUI------------------------------------HDD
    Boot Start-up of the machine BootROM
    G3FAX Control of the G3 FAX Board G3 FAX Board
    Dcon Control of the DC controller DC controller PCB Soldered to a flash ROM
    Rcon Control of the reader controller Reader controller PCB Soldered to a flash ROM
