ir 2520 printout is not good it shows black lines on the paper it is in views the fault of developing unit kindly go through the attachment and guide me how to solve this problem it is urgent
Tags: None
Re: ir 2520 printout is not good
The mag roll on the developing assembly? If you take it out and turn it by hand does it leak toner?Comment
when i turn it by hand it shows lines which used to print on the paper but with lot of attempt the lines on the mag rod removes and the print comes out properly but after 100 copies it again shows lines on the paper and same lines on the mag rod i had changed the drum but the problem is stillComment
It looks to me like a bad magnetic roller or blade."Who loves the roses,must also bear thumbs"Comment
You may need to clean the scanning unit too, both the stream reading glass and platen glass. Don't forget to clean the white roller beneath the ADF.Comment
