Initialized settings , New software, go to set up advanced box after config of controller. Got to RUI and UAC for advance box . Put in Default Log in Administrator and Password. Keeps coming back as invalid ? WTH!?
c5051 Cant Login to UAC For Advance Box ???? Invalid check user name and password
Tags: None
Re: c5051 Cant Login to UAC For Advance Box ???? Invalid check user name and password
7654321/7654321 ? Does it work from the UI itself to log you in? If not clear the pwd-clr under the clear menu of service mode to nuke it back to the default -
I did clear the Passwords. We are not talking about machine log in though. We are talking about Advance Box User access Control. Where you go to set up users . Thats in the RUI. The default password and log in there is Administrator and Password. It just wont let me in and I dont know where we can get it cleared or what.Comment
Username: Administrator (A is capital, and the rest of the letters are lowercase.)
Password: password
or try
1. Login to Settings/Registration with the system management account.
2. Turn on Authentication Management for Advance Box by executing the following.
Settings/Registration>Function Settings> Access/Stored Files>Advance Box Settings>Authentication Management = ON
3. Settings/Registration>Preference>Network>SMB Server Settings>
Use SMB Server =ON
4.Settings/Registration>Preference>Network>SMBServerSettings> SMB Auth Settings>
Use SMB Authentication =ON
On the same next to "Authentication Type" - enable both NTLMv1 and NTLMv2
5. Login to the RUI and select "User Access Control for Advance Box" and create
user accounts for the uses that require access to the Advance Box.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
This probably does not effect your case/ Just posted for others to note
imageRUNNER ADVANCE Series / imageWARE ADVANCE Desktop
SMB fails to connect to the Advanced Box after Microsoft Update
Microsoft released a high priority patch, MS11-043 (2536276) to fix a vulnerability in the SMB protocol on June 14, 2011. If authentication is turned off on the Advanced Box and patch MS11-043 is applied to the affected operating systems, access to the Advanced Box on the imageRUNNER ADVANCE models is rejected.
Affected Operating Systems:Affected Products:PROCEDURE:
To provide access to Advanced Box on the imageRUNNER ADVANCE models after applying MS11-043 please change the following settings to turn on SMB server authentication. Once these steps are complete any registered users will be prompted for their user name and password to make a successful SMB connection to the Advanced Box.
1.
2.
3. Restart the device after making the Advanced Box and SMB server settings.
4.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Check Mark.jpg**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
