IPF9000
  • mkopoiuy
    • Mar 2008
    • 54
    [Error Code] IPF9000
    I got ipf 9000, hardware error problem 03130031-2f3a.
    Someone knows this problem
    would let me know what is this problem.
  • tinnyjay
    • Oct 2009
    • 663
    Re: IPF9000
    Canon suggests replacement of carriage
    "Who loves the roses,must also bear thumbs"
    • Canuck
      Tech Specialist
      • 1713
      Re: IPF9000
      Huh???? That is a valve motor error....inside bottom of ink tanks. Carriage won't fix that
      • V-P
        • Apr 2011
        • 679
        Re: IPF9000
        The error points to
        A) the valve of the purge unit.
        You will need to remove the covers on the right side - inspect & test the purge unit for its functionality
        or replace it with new one and see what happens
        If the printer has a lot of usage I would replace the purge even if it is not causing errors.
        B) Carriage problem related to the pin of the purge
        Good luck !
        • Canuck
          Tech Specialist
          • 1713
          Re: IPF9000
          This error refers to the open/close of the ink supply valve,not the purge unit. Purge unit errors are 2f20 and 2f2d. If you pull off the ink tank cover you will see the valve motor unit
          • V-P
            • Apr 2011
            • 679
            Re: IPF9000
            If you are reading from SM than probably it is pointing you to the wrong direction.
            In copiers what you read in SM is about 99 % correct - but in LFP-s is about 50 % correct. At least that is my experience
            Anyway I don't like to start a debate on who's right or wrong....
            mkopoiuy can check both places himself and if he knows what to look for - he will fix the problem
            • Canuck
              Tech Specialist
              • 1713
              Re: IPF9000
              Yes its from manual....Also bulletins,my buddies at Tech Support.....I have been doing ipfs for many years...same code for 9400s,etc. Believe what you want...show me something to prove your position...there is nothing. Not here to get into a pissing match....I know i'm right. I just don't like to give misinformation...worse than none at all.
              • V-P
                • Apr 2011
                • 679
                Re: IPF9000
                On my book it says "purge unit"
