IR-3225 scanner tab is missing on display
  • copyhere
    • May 2009
    • 112
    Ive checked the usual setting of nw scan in service mode set to 1 and machine has only copy, fax , print, and meap tabs on display no scan is showing.
    The machine has the fax and UFR print kit in it. Any ideas why the scan screen wont show? Machine does not have universal send. But I want to use scan with color network scangear but im unable to do so with this missing.
  • doktor
    • 214
    Re: IR-3225 scanner tab is missing on display
    If i remember good check in service mode level 2 Copier- Option- User/Body?- UISCAN is set to one. This turns on the scan tab on the home screen of the copier.
      • 16083
      1. Enter Service Mode (press Additional Functions, 2 and 8 simultaneously, then Additional Functions).
      2. Enter Level 2 of Service Mode (press Additional Functions, then 2).
      3. Select Copier > Option > Body > UI-RSCAN.
      4. Set UI-RSCAN to 0 to remove the Scan tab. Set UI-RSCAN to 1 to display the Scan tab.
      5. Hit OK.
      Summary: UI-RSCAN = 0 will remove the scan button. UI-RSCAN = 1 will display the scan button.
      • copyhere
        • May 2009
        • 112
        Thanks Doktor and Tekat
        You saved me a lot of time I was almost going to have to replace the machine for the customer if it wasnt for you helping me out.
        Thanks a lot!
