Job Build ?
  • V-P
    • Apr 2011
    • 679
    Job Build ?
    Customer is requesting "Job Build" tool.
    meaning - he wants to print complex PDF files with a certain sequence of A4 than separator than A3 than A4 than again separator etc etc.
    He owns a bunch of Canon ir-s and irc-s. Of course solution should not be crazy expensive.
    Right now they are using a driver feature but they complain a lot because it is not professional and because a lot of errors and bugs.
    Ideas ?
  • songela
    • Mar 2008
    • 216
    Re: Job Build ?
    I would suggest you print the document to the Mailbox of the copier,
    i.e, Set the 'Output Method' to 'Store' in Properties of the Print Dialogue box
    Then print from the Mailbox and take advantage of options of the 'Additional Function' button.
    • teckat
      • 16083
      Re: Job Build ?
      Job Build function under Special Features on the copier, enables you to scan large-quantity originals by dividing them into multiple batches. The originals are then printed as one document after all the batches have been scanned. Job Build can also be used to scan documents which consist of several parts, each requiring different scan settings.
      Steps for Job Build Function:
      Copy
      1. Insert the first batch into the document feeder, making sure not to exceed the feeder’s capacity (e.g., 50 or 100 sheets), or place the first original on the platen glass.
      2. On the Copy tab, press [Special Features].
      3. Press [Job Build].
      4. Press [Done].
      5. Press [Start]. The first original(s) will be scanned
      6. When the scanning is done, insert the next batch into the feeder or place the next original on the platen glass. Change the settings on the pop-up screen if desired.
      7. Press [Start].
      8. After the last originals are scanned, press [Done] to begin copying
      Send (Universal Send)
      2. On the “Send” tab, select your destination or destinations.
      3. Press the Scan Settings drop down menu and select [Option].
      4. Make any necessary settings changes.
      5. Select [Special Features].
      6. Select [Job Build], then press [Done].
      7. Press [OK].
      8. Press [Start].
      9. When the scanning is done, insert the next batch into the feeder or place a new original on the platen glass. Change the settings on the pop-up screen if desired.
      10. Press [Start].
      11. After the last originals are scanned, press [Done] to begin the “Send.”
      Scan to Mail Box
      2. On the Mail Box tab, select the Inbox into which you would like to scan a document. Input the password if Inbox is password-protected.
      3. Press [Scan].
      4. Press [Special Features].
      5. Press [Job Build].
      6. Press [Done].
      7. Press [Start]. The device will scan the first original(s).
      8. When the scanning is done, insert the next batch into the feeder or place the next original on the platen glass. Change the settings on the pop-up screen if desired.
      9. Press [Start].
      10. After the last originals are scanned, press [Done] to begin scanning to Mail Box.
      Frequently Asked Questions:
      Q: Can I use Job Build with other features, such as Duplex and Stapling?
      A: Yes. Using Job Build in combination with other finishing features is an ideal way to leverage the power of your imageRUNNER device to increase productivity and create finished documents.
      Q: How does Job Build help increase productivity?
      A: By using Job Build when making copies of documents that exceed the feeder’s capacity, you can make complete sets without requiring additional collation. This reduces the total amount of time to make document sets.
      Q: Can I use Job Build to scan or copy documents using both the feeder and the platen glass?
      A: Yes. Job Build combines documents scanned or copied from both the document feeder and the platen glass.
      Q: I want to scan and e-mail a document from the imageRUNNER device, but some pages are one-sided and others are duplexed. What can I do?
      A: The Job Build feature is ideal for scanning documents with mixed settings. You can scan the one-sided batch, switch to Two-Sided Mode, scan in the next batch, and then switch the setting back to the One-Sided Mode.
      Q: Are there any restrictions to how many documents can be scanned with Job Build?
      A: No.
      Q: How do I access the Job Build function?
      A: Job Build is a standard feature of both Copy and Mail Box on most imageRUNNER devices and is located within the Special Features screens. When the device is configured with Universal Send, Job Build is also available when performing this function.
      • songela
        • Mar 2008
        • 216
        Re: Job Build ?
        A: By using Job BuildJob Build to scan or copy documents using both the feeder and the platen glass?
        A: No.
        As comprehensive as always!
        Kudo!
        • V-P
          • Apr 2011
          • 679
          Re: Job Build ?
          Thnx for the replies guys but (there is always a but) as I stated, they already use the printer driver (and mailbox) and it is not enough for them.
          Customer is printing PDF files (A3 drawings with a lot of layers and GIS). A4 mixed with A3.
          A typical file looks like this :
          4 pages text and chart in A4
          120 A3 drawings with some dividers
          10 A4 pages
          50 A3
          etc
          It is just printing. No scanning or sending involved. Originals are created by CAD or something similar.
          • teckat
            • 16083
            Re: Job Build ?
            10 A4 pages
            50 A3
            etc
            buy a Toshiba
            e-BRIDGE Job Build
            Highlights
            • Print different document types such as Word, Excel, PDF and others together as a set
            • Switch between single and double sided printing within a job
            • Combine A4 and A3 pages sizes within a job
            • Use Various Paper weights and colour
            • Save time sorting and collating!
            http://www.copyworld.com.au/document...dge-job-build/
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              Re: Job Build ?
              Not a free solution, but eCopy PDF Pro Desktop can do this quite easily.
              In its former lives it was known and eCopy Desktop and eCopy Paperworks.
              The customer can download a fully functional 30 day trial copy of it from eCopy... errrrr, excuse me, "Nuance".
              • V-P
                • Apr 2011
                • 679
                Re: Job Build ?
                buy a Toshiba
                e-BRIDGE Job Build
                Highlights
                that is exactly what I was looking for
                shame on Canon for not developing it too
                • teckat
                  • 16083
                  Re: Job Build ?
                  guess u have to go with Cannon's
                  http://www.usa.canon.com/cusa/office...ffice#Features
                  Document Distribution and Management
