can not enter service mode irac2020
  • Gbr
    • Nov 2011
    • 50
    [Misc] can not enter service mode irac2020
    hello
    I have a canon irac 2030L and i can not enter service mode with *28*,, i have also tried with *49*. the buttons are working fine and are not sticky. any help woul be much appreciated. thank you
  • vamoursly
    • Sep 2011
    • 273
    Re: can not enter service mode irac2020
    Try pressing the yellow cancel button first, then *28*
    V
    • Gbr
      • Nov 2011
      • 50
      V
      i have tried that, but no difference.
      thank you
      • andypo
        • Jun 2011
        • 6
        thank you
        * > 2 > 8 > *
        • Gbr
          • Nov 2011
          • 50
          Originally posted by andypo
          * > 2 > 8 > *
          Tried to press separately 2 and 8, as is in BW 1022.., but it doesn't work either. I will see if i get it to download mode tomorow.
          • doktor
            • 214
            First log in 7654321,7654321
            • vamoursly
              • Sep 2011
              • 273
              You are pressing the 2 and 8 together yes? If not Dude you are doing it wrong
              V
              • teckat
                • 16083
                hello
                Check for a stuck fax volume button switch. In the photo below, you can see that the actuator for the switch is actually stuck in the body of the switch. Replacing the Volume PCB Assembly resolved the issue. C2020 / C2030 ==FM4-1198-000, Control Panel Volume Assembly.
                Security features
                To prevent unauthorized access to Service Mode, Password set is enabled.
                ■■ Related service modes
                • COPIER > OPTION > FNC-SW > PSWD-SW (Level1)
                Set password type for transition to service mode.
                <Setting range>
                0: No password (default)
                1: Service engineer
                2: System administrator and Service engineer.
                • COPIER > OPTION > FNC-SW > SM-PSWD (Level2)
                Password for service engineer for transition to service mode.
                <Setting range>
                To reinforce the security, change the password from a default.
                ******** (eight digit numeral) [default: 11111111]
                After the above setting, to enter Service Mode, enter password screen will appear.
                MEMO :
                If Service Engineer’s password is forgotten, password function is cancelled by using
                Service Support Tool (SST).
                • teckat
                  • 16083
                  Service Mode Classic Level 1 follow the steps bellow:
                  1) Select Settings/Registration
                  2) Hit 2 & 8 at the same time
                  3) Select Settings/Registration
                  To go to Service Mode level 2, go to Service Mode level 1 and then:
                  1) Select Settings/Registration.
                  2) Select 2.
                  Go to Service Mode follow the steps bellow:
                  4) Select Mode List
                  5) Select Copier
                  6) Select Option
                  7) Select FNC-SW
                  8) Highlight [Level 1] to toggle between level 1 and level 2.
                  you can change the way you enter the Service mode, by going into COPIER>OPTION>FNC-SW>SVMD-ENT.
                  0 = * 2 and 8 *
                  1 = *4 and 9 *
                  • Gbr
                    • Nov 2011
                    • 50
                    [ATTACH=CONFIG]24108[/ATTACH]
                    Security featuresMEMO :
                    Hello
                    So if there would be a password set, I would be able to get to enter password screen? Which i don't.
                    I will check fax volume button in the morning, and let you know. thank you
                    • teckat
                      • 16083
                      Hello
                      That was just a note for future ,good luck
                      • Gbr
                        • Nov 2011
                        • 50
                        I was logged in, and can operate all of user settings, but nothing happens when i want to enter service mode (it opens settings/registration at end), on other machines, some of same series i was always able to enter with *28*, on the small one *>2>8>*
                        • Gbr
                          • Nov 2011
                          • 50
                          The problem was in fax volume button.
                          Thank you for helping.
                          • teckat
                            • 16083
                            Thanks-
                            : the act of looking at something closely in order to learn more about it, to find problems, etc. : the act of inspecting something
