ir2270 right door stuck
  • lyozsi
    [Jamming] ir2270 right door stuck
    Hi Everyone,
    I have an IR2270, and the right door is stuck. If I push the button, it only opens a few centimeters.
    Do you have any ideas how to open it without breaking anything?
    Thanks,
    Lyozsi
  • northernlife
    • Sep 2011
    • 847
    Re: ir2270 right door stuck
    The fuser pressure latch (White piece on the fuser that slides the pressure) isn't releasing properly. You can give it a decent tug and it will open. Check to make sure that the door didn't come off on of it's hinges. I do believe there is a mod for this issue, there is FM2-0355-010
    • lyozsi
      Thanks, Northernlife, it worked.
