Canon Imagepress C1 image transfer belt ????
  • digitalpressvietnam
    • Jun 2012
    • 51
    Hello everybody ?
    Anyone use Canon IRC6800 Image Transfer Belt for Canon Imagepress C1 ??? I see same size but different about material
  • teckat
    • 16092
    Re: Canon Imagepress C1 image transfer belt ????
    Originally posted by digitalpressvietnam
    Hello everybody ?
    DO NOT ATTEMPT TO USE
    can't imagine if the 2 reflecting surfaces inside belts for HP would line up
      • Jun 2012
      • 51
      How do you think if insert 2 white tag inside the belt for HP can work ?
      • teckat
        • 16092
        ______:_
        Both belts have the white reflectors inside--see if they match up
        U can not use tape or other material inside belts
        Why don,t u just buy the correct item
        Are u a tech ?
          • Jun 2012
          • 51
          Ok I see, thanks so much Mr.Teckat. I should buy correct belt for C1
          • Herrmann
            • Jan 2006
            • 792
            Why not? if its the case that you have the 6800'belt already there and you not have to order it, give it a try. You have nothing to loose. There will be no damage, if the marks dont fit, the mashine will code out with an error.
            i would try it.
            If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
            • teckat
              • 16092
              i would try it.
              Differant material >differant primary transfer voltage& rollers
              • fotoc
                • Jul 2024
                • 1
                Good afternoon! Please tell me if there is a replacement for the original transfer belt for the canon c1
