AUTHORIZED SEND (customized MEAP application )
  • browny
    • 81
    Hello all .
    Do you know about Advance Authentication n the CANON MEAP : customized authorized send solution : how can we get the INSTRUCTIONS (service manual ) & SOFTWARES for IR canon machines ( I believe the new MEAP applications ) .Thank you.
    • 16083
    Re: AUTHORIZED SEND (customized MEAP application )
    Authorized Send==INSTALL_CONFIG_GUIDE_V3.5.1.pdf
    Authorized Send--USER_GUIDE_V3.5.1.pdf
    From the Authorized Send Configuration Screen, you can configure the settings as necessary to use Authorized Send.
    1. Open a browser window, enter the following URL:
    http://<device ip>:8000/AuthSendConfiguration
    (Replace <device ip> with the IP address of the MEAP device.)
    The Authorized Send Configuration Screen is displayed.
    IMPORTANT - Enter AuthSendConfiguration exactly as shown, as it is case-sensitive.
    If Portal Service is installed, you can also access the Authorized Send Configuration screen by entering http://<device ip>:8000 . click the Authorized Send Configuration link.
    Enter your user name in [Login ID] and your password in [Password], press [Login].
    The default Login ID is 'Administrator', and the default password is 'Admin'.
    • browny
      • 81
      Originally posted by teckat
      [ATTACH]24179[/ATTACH]
      [ATTACH]24180[/ATTACH]
      Thank you for reply. But that is not what I mean. I needs to know how to install the Meap. And configuration for Canon machines don't have that. : where we can get the software ( buy from Canon ?) and Service manual for that. ( I think this for Canon Advance ? ) I see that. But how to install & service that options.
        • 16083
        http://www.usa.canon.com/cusa/office.../alliance_meapy
        You will need a valid license filein order to install a MEAP application. If your application comes with a License Access Number, you must access theLicense Management System atthe following URL to acquire your license file: http://www.canon.com/lms/license/Follow the online directions to create and download your license file. You will need to have your License Access Number and your MEAP deviceserial number(s) available in order to complete thelicensegeneration process. If your application does not come with a License Access Number, your licensefilewill beprovided by your MEAP Application provider.
        • kampai
          where can I get an application Authorized Send for MEAP?
          Thank you.
