irc3080 toner not load in to drum unit
  • jaruwit
    • Nov 2013
    • 10
    [Electrical] irc3080 toner not load in to drum unit
    irc3080 run out toner. it not load black toner in to drum unit.
    I test motor M11 COPIER>FUNCTION>PART-CHK>MTR. It ok. I open front door and hack hardware door sensor to see motor. it turn.
    I try service mode level 2 COPIER>FUNCTION>INSTALL>INIT-K. it not turn.
    How to repair?
  • northernlife
    • Sep 2011
    • 847
    Re: irc3080 toner not load in to drum unit
    Developer on these are driven by a clutch on the drum drive assembly. CL4 FM2-3581
    • teckat
      • 16083
      • jaruwit
        • Nov 2013
        • 10
        I test motor CL4
        COPIER>FUNCTION>PART-CHK>CL 4
        COPIER>FUNCTION>PART-CHK>CL-ON
        It say "OK!"
        But I can't see component clutch working or not.
        Is it say "OK!" mean it work OK? Or I must check hardware to make sure it work or not.
        • vamoursly
          • Sep 2011
          • 273
          Do an autograd, is the black line missing? If so change the clutch.
          V
          • teckat
            • 16083
            Originally posted by jaruwit
            I test motor CL4
            It say "OK!"
            that is just a signal check/ does not mean hardware is functioning
