Old IR c3080i
  • mo0651
    • 1054
    Old IR c3080i
    This copier is needing a transfer belt. Can I reset the counter or is this a fused reset?
    • 16083
    Re: Old IR c3080i
    Transfer Belt has nothing to do with Fuser--
    U mean CLEAR special counters (DRBL-1/DRBL-2)
    COPIER>COUNTER>DRBL-1
    COPIER>COUNTER>DRBL-2
    <Example>
    TR-BELT / 00000201 / 00240000 / 0% / !! / 000082
    [1]--------[2]----------[3]------[4]---[5] [6]
    [1]: Displays the part name. In this example, the intermediate transfer belt unit.
    [2]: Displays the counter value (actual number of sheets used). The value is cleared by pressing the clear key when the part is replaced.
    [3]: Displays the limit value (number of sheets as guideline for replacement). You can select the item and change the value with the numeric keypad. After changing the value, press the OK key.
    [4]: Displays the ratio of the counter value to the limit value.
    [5]: When the ratio is between 90% and 100%, a single exclamation mark (!) is displayed.
    When the ratio is over 100%, two exclamation marks (!!) appear. In the example above, no exclamation marks would appear.
    [6]: Displays the predicted number of days until replacement. The example above shows 82 days.
    what message are u receiving ??
    u mean the "Replace Fixing Assembly" Message
    or "Get ready to replace the fixing unit"
    • mo0651
      • 1054
      Re: Old IR c3080i
      On some copiers when a transfer belt is replaced, it actually uses a fuse or resistor to reset the counter in the machine. That is what I meant by that counter. The belt has a counter and I was wondering if I could reset that count manually? Or does it use a fuse to reset so the machine knows it has a new Belt.
        • 16083
        Re: Old IR c3080i
        u can re-set durables messages as posted above
        no fuse on this ITB belt
        • mo0651
          • 1054
          Re: Old IR c3080i
          Awesome thanks for the tips!
