irc 2880 error e003-02
  • pontiac
    • 420
    I only have one of these units in the field and I have no spare parts to test with. Copier shuts off after about 30 seconds sometimes the e003-02 error displays sometimes the screen goes blank and nothing is displayed. Tried sim reset numerous times no luck so before I buy a fuser unit just wanted to ck if there is something else to check thanks for replys.
  • jrgf67
    • Feb 2010
    • 37
    Re: irc 2880 error e003-02
    Greetings. Maybe the problem is in the switch of the door does not act properly. I attached picture.
    • vamoursly
      • Sep 2011
      • 273
      I have had this myself on a few IRC 2380i, ended up being the lower white plastic door hinge supports;
      Easiest thing to check is the side door not closing correctly, take a read through this thread;
      http://www.copytechnet.com/forums/sh...ght=door+hinge
      I would then remove the fuser and visually inspect, look for ease of rotation first
      V
      • pontiac
        • 420
        Actuator plate was the problem, slightly bent and not actuating SW3. Thanks for the replies.
