machine shows error code of E804 sub 101. looks like a fan problem but don't know where the fan is.need some reliable information on this thank you.
clc 1110
Tags: None
Re: clc 1110
E804-0101
is this the error sub-code
if so> FM1=Original exposure system cooling fan 1
Cools the original exposure system.
2-speed control (voltage)=Yes (24/15V)
The rotation of some of the fans used in the copier is controlled so that they operate at full speed (24 V) or half speed (15 V) in response to a switch of voltage by the voltage switching circuit of the respective fan.
If an error occurs in the rotation of a fan, the copier indicates ‘E804’ on the control panel. To reset the copier, remove the cause, and turn on the power switch.
FM1=FH6-1575-000
Air filter (FM1) FB4-4819
FM1.JPG**Knowledge is time consuming, exhausting and costly for a trained Tech.**
