irc3580
  • akm
    • Sep 2012
    • 155
    [Misc] irc3580
    Dear/ CopyTechTeam,
    please i want your help for the problem witn irc3580 that after change new drum unit BK the copy still have a white thin line even after make full graduation adjust - clean the shutter of lazer unit as the attachment
    thanks
    akm
    • 16083
    Re: irc3580
    Originally posted by akm
    Dear/ CopyTechTeam,
    thanks
    akm
    [ATTACH=CONFIG]24285[/ATTACH]
    is that a GLASS COPY or a Network Print
    what direction is that line paper feed <_____>
    or cross-feed (front to back)
      Re: irc3580
      Looks to me like a bit of crap has fallen onto the laser glass, but that's only a guess, more information is needed.
      • akm
        • Sep 2012
        • 155
        Re: irc3580
        [ATTACH=CONFIG]24292[/ATTACH]
        it is a network print and the white line appears in the sub scan (paper feed)
          • 16083
          Re: irc3580
          so white line is not on a Glass Copy at all ???
          CHECK YOUR INTERNAL TEST PRINTS BELOW
          Print out a PG4
          - White Line
          If a white line is found in the image, suspect a fault in the developing system.
          Also do a Full Page Halftone (TYPE=PG5)
          MEMO:
          - You can print out test prints for individual colors by making the following selections in service mode:
          COPIER>TEST>PG and then COLOR-Y/M/C/K.
          - You can also change the density of the test prints by making the following selections in service mode:
          TEST>PG>DENS>Y/M/C/K.
          MAGENTA EXAMPLE BELOW
          White Line
          If a white line occurs, suspect a fault in the ITB unit, secondary transfer outside roller, or laser exposure system.
          PG10
          Check for white lines associated with development on a specific color.
          If a white line is found in a specific color, suspect a fault in the development system, transfer system and drum of that particular color
          • mo0651
            • 1054
            Re: irc3580
            what does the developer roller look like?
              • 16083
              Re: irc3580
              Are u a tech ???????????? / go in service mode and run those test prints if u know how
              in the Drum Cartridges in this model//
              The machine's imaging system consists of a photosensitive drum, developing cylinder, 4 drum units containing
              carrier, 4 toner containers, ITB unit, fixing assembly, and secondary transfer outside roller
