mode no. in service mode
  • adel_nathan
    • Jul 2011
    • 103
    [Misc] mode no. in service mode
    hi every body
    i want to know where in service mode i found the modle no. ( ie. IR 2000 , IR1600 ...act)
    for this modle
    IR 2000 , IR 2020 , IR 2020i , IR 3570 , IR 5000
    for nessecary please
    thank
  • teckat
    • 16083
    Re: mode no. in service mode
    Originally posted by adel_nathan
    hi every body
    for this modle
    thank
    u mean the Serial # & Model ?
    hit the counter check button
    look in lower portion of screen
    bottom left corner of the display will show the serial number, the iR model and the version series.
    if not seen
    some printers have it disabled--
    Check in service mode to see if this feature has been disabled. COPIER > OPTIONS > USER > CNT-DISP.
    The default setting is "0", which enables the display of the serial number when pressing the counter check key. Set to "0" to enable display of serial number, set to "1" to disable.
    To print the serial number (along with other information): 1. Enter Service Mode by hitting Additional Functions, 2 and 8 simultaneously, and then Additional Functions.
    2. Hit COPIER.
    3. Select FUNCTION.
    4. Select MISC-P.
    5. Select P-PRINT.
    5. Hit OK.
