Canon IR7105
  • mramlawi
    • Jul 2011
    • 838
    Canon IR7105
    Dear all ,
    i have a canon 7105 the bypass not workin faslty gives jam ,when the copier is ready the pickup roller moves down and the rollers not roller ,i changed the Bypass rollers and also theres unit behind the by pass i changed and still facing the same problem
    Distinguished road makes you jewel in rough
  • vigour
    • Aug 2010
    • 1038
    Re: Canon IR7105
    Check if the solenoids in the multifeeder are working.
    Double check if you put the guide plates back properly
    • teckat
      • 16083
      Re: Canon IR7105
      Originally posted by mramlawi
      Dear all ,
      iR7105--------Check the state in I/O Mode
      <DC-CON>
      address-bit-
      P002- 0- manual feed curl-removal sensor PS68/ 1: paper present
      P002-10- manual feeder transport sensor PS35 /1: paper present
      P004-12- manual feeder tray paper sensor PS17 /1: paper present
      P005-10- manual feeder tray cover open/closed sensor PS56 /1: closed
      P013-1- manual feeder tray pickup clutch CL7 /1: ON
      P013-2- manual feeder tray transport clutch CL18 /1: ON
      P014-3- manual feed pickup latch solenoid (return) SL6 /1: ON
      P014-4- manual feed latch solenoid (pull) SL6 /1: ON
      <FEEDER>
      P004-7- manual feeder registration roller sensor S9 /1: original present
      P008-7- manual feeder original sensor PI12 /1: original present
