E0110-0101 /E110-0201
  • Joseph2011
    • Aug 2011
    • 88
    good morning:
    I have a poblem with imagePRESS 6000 -0201 get the code E0110, I've exchanged with another laser to another machine and get the same code, and if I place it in another position other laser goes another code E 0110-0101 I've been exchanging laser the other machine but the code keeps coming.
    what else I can do
    thanks
  • teckat
    • 16083
    Re: E0110-0101 /E110-0201
    Originally posted by Joseph2011
    good morning:
    what else I can do
    thanks
    check your connections
    When replacing the laser scanner unit, it has to be performed carefully because a measure to be taken will vary depending on the following
    replacement conditions: whether installing the removed unit to other machine/different station (color) or not, whether color of the unit to be
    removed is M-color station or Y/C/Bk-color station.
    <When Removing the Laser Scanner Unit>
    Execute the measure in accordance with the table indicated below before removing the laser scanner unit. After replacing the unit, execute "After Replacing the Laser Scanner Unit".
    When replacing the new laser scanner unit, execute either Measure A or Measure B.
    READ PDF--------
    E110-0x01=
    x
    = 1:Y 2:M 3:C 4:Bk
    1. Check if the connector at laser scanner unit is disconnected/not securely inserted -> disconnect and then connect the connector
    - connector at the laser scanner unit
    - connector at the DC controller PCB 1-3 (UN240)
    2. Check if the harness between the laser scanner unit and DC controller PCB 1-3 is disconnected/caught by a unit
    3. Replace the laser scanner unit
    4. Replace the DC controller PCB 1-3
    • Kwaku01
      • Aug 2018
      • 121
      good morning:
      what else I can do
      thanks
      I bought canon imagepress c6000 secondhand. After installation, I keep getting error after errors. The new errow is, E110-0201. I've no clue how to go about this one...any help will be greatful!
