White lines on ir5870c
Re: White lines on ir5870c
check white plate----------for glass copy issues
stray dust inside the reader unit collects on the white plate, showing up as lines in output images.
cross-feed = front to back
these are some blank spots & not directly thru the entire image (see lower 1/4 of image as shown)
Check the Secondary Transfer Outside Roller SURFACE---
is this a glass copyis this on colors ? or BLACK ONLY ?(check Black developing cylinder)
post a Full Page Halftone (TYPE=5) test print
white spot images outlined in green inside red outlines have the exact same image & spacing between , as u can see
image.JPG**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Copy or print give same result. I've replaced secondary roller with another and no changes.
Tomorrow I'll try (TYPE=5) test print. On first look distance between two white lines correspond in diameter for (FM2-6857-000) roller unit, but I see no way that would affect the image transfer like this. Is it possible that the problem is in the HV?
P.S.
On this machine I replaced the HD and after deleting R-CON and D-CON I entered the parameters of the P-print.There is no stupid question, just stupid answerComment
P.S.
did u check the fix roller & pressure for a flat spot/or spots
To help prevent the premature deformation of the Upper Fuser Roller is to change the setting of FX-CROT in service mode. The default setting for FX-CROT is set to 0. Try Changing the setting from 0 to 3.
Enter service mode level 1 (* 2 8 *), select Copier > Options > Body > FX-CROT and change setting accordingly.
center measurement distance between Line 1 & Line 2 is same> as between Line 2 & Line 3
funnybut did u check the paper stock ?
Last edited by teckat; 03-14-2014, 12:29 AM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Yeap... I had to replace colors starters and black developer unit. Now, finally working as it should. In addition, I changed all the primary rollers and cleaner unit. I decided to replace these with a copier models Canon iR5075, iR7105 and BH1051. Far fewer problems in maintenance. For the purposes of colors I like to use iRC5185i. If someone in Europe has the above B/W models on sale and they are in very good condition, let me privately contacted.
Teckat thanks on advice and help.There is no stupid question, just stupid answerComment
good luck, usually comes down to process of elimination on check list**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
