E015 in IP1135
  • wassem
    • Aug 2012
    • 166
    [Error Code] E015 in IP1135
    we have E015 and the sub code 1019
    we changed the pre registration unit
    we tried the buffer driver PCB
    we tried DC controller
    we tried the relay board
    and still the same problem
    anyone have any idea
  • Joseph2011
    • Aug 2011
    • 88
    Re: E015 in IP1135
    good afternoon:
    you comment error is due to problems in the pre-registration of the machine (zone B)
    You should check the cables, clean the sensors and check engine even if the continuous problem with that should change the sensor wires is code
    FM3-7780-000
      • 16083
      Re: E015 in IP1135
      What is Firmware ver. ?????
      Connection Issue I Bet
      Check for Dust built up on all 24V DC power supplies & Check all the connections
      Cleaning the dust off
      • wassem
        • Aug 2012
        • 166
        The Surprise
        we have solved the problem
        there was a drop in the 24v in the relay board
        the reason is the front door switch
        and that make that error (E 015)
          • 16083
          Re: The Surprise
          • Zela
            • Mar 2014
            • 25
            Re: E015 in IP1135
            Please advice.
            I'm seeing the IP1110 error E015-1056 and I can not find it anywhere. According to SM should it be something in the feeding unit but do not know what ........
              • 16083
              Re: E015 in IP1135
              Originally posted by Zela
              Please advice.
              Reverse roller switch motorOver-current detect/ this is a TWO-PHASE SWITCH MOTOR
              Check the connector of the reverse roller switch motor (M56), and replace the motor if necessary.
              Outer delivery unit
              Delivery buffer unit
              (front)
              Reverse unit--
