Canon IR6570 Blank Bands on copies
  • SAZ911
    • Mar 2013
    • 193
    Hi fellow tech's
    Need your help with a little issue I'm having with a Canon IR6570 that is producing blank bands on the copies from top to bottom (portrait). I know its got something to do with the Developing Assy, either its shorting / arcing, so ive gone through the coronas in the various assemblies and all seems well. the problem is intermittent and will happen roughly every 5-15 copies/prints
    just wondering if anyone has come across this before, and knows something i don't.
    I have attached some sample sky copies I made...
    thanks as always...
    0005_001.pdf
    SAZ911..........
  • elamurugu
    • Mar 2014
    • 27
    Re: Canon IR6570 Blank Bands on copies
    paper separation charge drop, cheak the transfer carona endblock.
    • mediakarya
      • Mar 2014
      • 2
      corona wire cleaner
      • COPIERTEC ASSOCIATES
        • Aug 2011
        • 279
        When such a scenario happens,is there any sound made by the machine?
        If not check on the drum unit assembly,there could be an abnormal load
        on the waste toner system.
        Sometimes there is a belt at the machine rear which drives the waste toner
        system,when it is worn out it can also cause that scenario.
        • canonbundy
          • Jun 2012
          • 607
          I would run with the Corona Wire Cleaner suggestion - The Cleaner can get stuck as it performs it's Wire Cleaning, try Wire Cleaning to bring the Cleaner back to home position SETTINGS/REGISTRATION > ADJUST/CLEANING > WIRE CLEANING.
          • SAZ911
            • Mar 2013
            • 193
            Hi All,
            thanks for your replies.
            it was the transfer corona assy, re-strung corona and thorough clean.......A for Away...
            SAZ911..........
            • Rachid.Akli
              • Oct 2011
              • 595
              The attached print is an A4 size not A4R.....
              Rachid
              "Find a job you love and you’ll never have to work a day in your life." Nagy's father
              • Rachid.Akli
                • Oct 2011
                • 595
                Hi,
                Clean or replace the developing clutch CL1.
                Rachid.
