IRADV C5030 ADF Problems
  • jmandassociates
    • Sep 2008
    • 186
    Working on an IRADV C5030. It was getting an E000732-0001 scanner communication error. We replaced the reader controller PCB and that error went away. But now w
    • 16083
    Re: IRADV C5030 ADF Problems
    Original Tray On The Document Feeder Is Not Lifting
    Replace the Paper Surface Sensor (SR6) should resolve this issue. =WG8-5783-000
    • spectraindo
      • May 2008
      • 313
      Because you have replaced the Reader Controller, you must setup the ADF settings.
      Go to SERVICE MODE > FEEDER > FUNCTION > SENS-INT.
      Slide the ADF Paper guides to A4.
      Press FUNCTION > TRY-A4 > OK
      Slide the ADF paper guides to A5R
      Press FUCTION > TRY-A5R > OK
      Now you can use the ADF.
      • jmandassociates
        • Sep 2008
        • 186
        We replaced the Paper Surface Sensor and did the ADF settings and it's still not raising the tray. Any other ideas?
          • 16083
          Check ADF sensors in IO mode
          Also in service mode ,check for last or any alarm codes,
          List here-- they sometimes point directly to hidden issues
          • Jaycat718
            • Oct 2013
            • 70
            Did you clear the RCON, and re-input values after you replaced the adf?
            • CT Copier Repair
              • Mar 2010
              • 304
              reinput rcon values
              did all the inits
              is still not lifting paper
              the adf feed assembly does not lift up its in the down position and does not init up on power up
              Running motor 0 it tries to turn can feel the motor getting a signal ie hard to turn
              sent board out for repair came back good
              replaced motor and motor harness
              MEchanical issue in the drive train
              ive looked and it appears to be ok
              • Herrmann
                • Jan 2006
                • 792
                sounds like a reader power supply problem for me--> if the adf tries to run it will draw current and the pws shut down. check for bad soldering joints and resolder, this is a common problem here since the using of lead free solder.
                The tree huggers stroke again
                If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
                  • 16083
                  Originally posted by CT Copier Repair
                  reinput rcon values
                  did all the inits
                  ----__----
                  Then it's all about receiving the correct voltage supply.
                  Did u check supply V ?
