z fold jam in ir 4570
  • wellrajive
    • Oct 2013
    • 31
    [Jamming] z fold jam in ir 4570
    pls help me...
  • elamurugu
    • Mar 2014
    • 27
    Re: z fold jam in ir 4570
    Z Fold paper come from witch casset. That casset pickup assambly in side is onside rotate gear not rotate properly.Replace the gear.
    • wellrajive
      • Oct 2013
      • 31
      first cassate......
      • Brian8506
        • 1665
        A jam code would help. Check pre reg flag to see if its hanging up. That could give an 0201 code. If so, replace the damper pad at backend of flag
        • ARUN MISHRA
          • 80
          r&d in registration lever and senser ..........
          sigpicARUN KUMAR MISHRA
          • northernlife
            • Sep 2011
            • 847
            so one thing that'll cause jams near the reg assembly is an old pre modded door (you can tell this because it has this black foam crap all over the lower left door, should be a metal bracket).
            Also, the registration flag can wear down, it as well should have a metal doodad on the flag itself, the flag itself bottoms out on a piece of foam that will stick and prevent the sensor from tripping properly.
            We do need a jam code in order to tell you exactly what's going on as we can only guess so much.
            • JeyJey
              • Dec 2014
              • 5
              I was having the same problem, z folding, jam code 0201, i read in a post here in the forum about this metal bracket, removed the metal and... well the machine is working flawlessly.
