iPF 5000 Multi Sensor Calibration - SENSOR CALIB Function Missing
  • Chromix
    My iPF5000 printer had some paper jam and related to that a Multi Sensor Error. After that it printed with a color cast.
    The sensor itself seems to be ok and therefor I intended trying to do a recalibration. I ordered the test chart FY9-9323 that is needed to do that and after I got it I started the calibration process according to the service manual.
    First I used the function
    SERVICE MODE > ADJUST > GAP CALIB
    and this worked just fine.
    After that the function
    SERVICE MODE > ADJUST > SENSOR CALIB
    should be used in conjunction with the test chart.
    The problem is that there is no SENSOR CALIB function in the ADJUST submenue!
    Any ideas? Do I have to do something to get this function (apart from entering service mode)?
