We have been having this problem for a while. It seems to happen once the printer is heated up with multiple page documents or multiple copy printouts. Starts with lighter magenta lines in the white areas and gets darker as more prints are done. Seems to go away once the printer cools down. All of the drums have been replaced and the problem still exists. Any ideas, adjustments, maintenance, etc that you can give me would be appreciated.
C4080 magenta streaks on multiple pg prints
Tags: None
Re: C4080 magenta streaks on multiple pg prints
using OEM DRUMS ? / Pull out the M DRUM & inspect it's surface when u start to see M Lines
what direction are these lines ?
main scan (front to back)
sub scan (paper feed direction)
SUB SCAN.JPG**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
rweymer
The drums are sealed with just a roller showing. The streaks on the actual print go the direction of paper feed (17" side of 11x17), were there before we changed the drums (months ago) and never went away after changing them out.Comment
what have u done to check on this printer ?
are u a tech >? if so when was last time u cleaned & inspected interior of printer ?
Pull out the ITB UNIT> remove metal plates> clean both sides>replace them**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
rweymer
I am not a tech, but have had experience maintaining and repairing different printers and digital presses through my printing career. I thought the problem could be beyond my knowledge of the machine, tools available and I was busy at the time so we had a tech out who cleaned and found nothing wrong with it other than the drums being low so we changed them out. Should I use (or not use) anything specific to clean the transfer belt?Comment
