Need to know how to turn the clear developer off in service mode. I have one giving on error code E020. They don't use it so I need to disable it.
Thanks for your help.
======================== After changing the setting, follow the shutdown sequence to turn off and
on power in order to enable the setting value
COPIER > OPTION > BODY > CLCONFIG
- In case of 4-color model, make sure that this setting is set to "1"
CLCONFIG Switching of 5-color/4-color configuration
Change the 5-color/4-color configuration of the engine.
0: 5-color mode, 1: 4-color mode
* Data is retained in both MN-CON and DCON.
1
Setting range: 0-1
Factory setting value: 0 ================================================== ========
COPIER > OPTION > BODY > L-MX-SET: set to"0"or OFF
L-MX-SET = Adjustment of the L toner deposit (Supporting 100% deposit)
When this item is set to ON, 100% deposit is specified.
Setting range: OFF/ON Factory setting value: OFF
