The Paper is Jammed - c2020i
  • ivartyn
    • Mar 2014
    • 6
    My ir adv c2020i gives an error message "the paper is jammed" when you try to print from tray 1. Yet there is no paper that is jammed.
    I suspect a sensor problem but not sure.
    Any help is welcome.
  • northernlife
    • Sep 2011
    • 847
    Re: The Paper is Jammed - c2020i
    either bad pickup tires. settings/registration, 2+8, settings/registration > Classic > Copier > Display > Jam
    give us what's listed there we'll tell you what to change.
      • 16083
      check PS14 /Cassette 1 Paper Level Sensor
      Cassette 1
      There are 2 sensors to detect the paper level and paper presence in the cassette.
      The paper level is displayed in three levels in the Control Panel.
      what does it show on panel
      check/post the jam code in history----?
      • ivartyn
        • Mar 2014
        • 6
        Can't see settings/registration > Classic > Copier > Display > Jam. I've attached a screenshot of what i have.
        • northernlife
          • Sep 2011
          • 847
          your screen will change, settings, 2+8 at the same time, settings registration again. may take u a bit a=if you arent used to it, other than rds its the only way to see the jam code
            • 16083
            advise to get a manual/ u could mess things up in service mode
            • ivartyn
              • Mar 2014
              • 6
              No Date Time1 Time2 L Code P CNTR Size
              1 0403 1726 1726 00 0102 02 741 A4
              2. 0402 1512 1512 00 0105 01 87 A4R
              • northernlife
                • Sep 2011
                • 847
                0105 is usually pickup roller tray 1, don't know why it's not a 0101 but it is what it is.
                0102 is delay jam out of tray 2.
                I'd try a set of pickup rollers.
                • vamoursly
                  • Sep 2011
                  • 273
                  test print from cassette 2 if it prints - you can bet your best friends hot moma that its those rubbish and I say that nicely cassette 1 paper pick combination, seriously poor design there;
                  Take the feed roller out, dead easy, just push one way out it will come; I bet only 10% wear on the one area, simply move the rubber around so it has some good tread, until you can get a spare in
                  Rubbish machines designed and built by Bob the builder and Thomas the tank Engine....
                  V
