Default Color Mode
  • thadwald
    • Feb 2014
    • 74
    Default Color Mode
    Hi,
    I have a Canon IR C5180 with a Fiery H1 server. I would like to set the default color mode of the printer to greyscale. Where do I do this?
  • mramlawi
    • Jul 2011
    • 838
    Re: Default Color Mode
    Click on the (*) choose the printer settings in the pages there somthing inside let you choose if you want full color, grey
    Distinguished road makes you jewel in rough
    • thadwald
      • Feb 2014
      • 74
      I have three options in my printer driver settings; printer default, CYMK, and greyscale.
      When I choose printer default, I get CYMK. How do I change printer default to be greyscale? Note that I would much rather change a setting on the printer than configure drivers on all computers that use the printer.
      The reason I have for wanting this is that all of our users need only black and white, most of the time. (This is a school.) Printing color is much more expensive with the machine's service contract.
      • thadwald
        • Feb 2014
        • 74
        I have looked again and couldn't find it. Is this feature/option available?
        • teckat
          • 16083
          set a Color imageRUNNER to copy in black mode by default----
          From the Display Panel of the imageRUNNER change the setting from "Auto - Color" to "Black" using the pull down menu.
          Press Additional Functions
          Select Copy Settings
          Scroll down to select Standard Settings
          Select Store
          Select Yes
          Select Done
          Now when making copies from the glass, the imageRUNNER will automatically default to Black only.
          • thadwald
            • Feb 2014
            • 74
            Select Store
            Select Yes
            Select Done
            Thanks for the reply.
            This will change the default for making copies from the glass, but it will not effect the default color mode for printing. I would like to set the default color mode for printing. The driver on all of our computers default to the color mode "Printer Default," which is CYMK. I would like to change the "Printer Default" to be Black only.
            • teckat
              • 16083
              Setting Print Server Driver Defaults To Black And White
              The Print driver needs to default to black and white printing when distributed from a print server. Network administrator does not want to change each new workstation driver install individually to default to black and white printing.
              Driver will be pushed down from print server.
              Follow the directions below for PCL and UFRII Print Driver Settings:
              Go to the properties of the PCL or UFRII print driver on the server.
              Click the Advanced Tab and then click on the Printing Defaults... button.
              Click on the Quality Tab and click on the drop down arrow in the Color Mode Field. Choose Black and White as the Color Mode, Click Apply and click OK.
              Click OK one last time and reinstall driver from share printer on the workstation.
              Follow the instructions below for the PS Print Driver Settings:
              Go to the properties of the PS printer driver on the server and click on the Printing Preferences button.
              Click the Color tab and select Black and White from the Color Mode: drop down menu.
              Follow these instructions below for the Fiery PS Driver Setup:
              Right click on the Fiery Driver and click on Properties. Click the Advanced Tab and then click on the Printing Defaults... button.
              Click on Color, choose Grayscale and click the Expert Settings... button.
              On the Black Color Setting Profile, click on the Black Text/Graphics drop down menu and choose Pure Black On, click Update.
              • teckat
                • 16083
                downloadable pdf
                Setting Printer Driver Defaults on a Windows Print Server To Black And White.pdf
                • northernlife
                  • Sep 2011
                  • 847
                  Not too familiar with the fiery's but add functions > Printer settings > Colour mode will set the colour mode for the printer itself, for everyone
                  • teckat
                    • 16083
                    don't think that will work on a room full of workstations ?
                    the posted pdf works
                    • northernlife
                      • Sep 2011
                      • 847
                      the pdf works on a domain, on a peer to peer you'll need to do it on every workstation. This would disable colour printing entirely. It's friday, gotta stir the shit a bit ;-)
                      • teckat
                        • 16083
                        • vigour
                          • Aug 2010
                          • 1038
                          I thought of telling him the same thing BUT the driver overrides those settings.
                          Adjusting the Printer Default on all his computers seems to be the only way.
                          Or enabling ID modes with a pass through for Black only
