IRAV C9065
  • mbcruzin
    • Aug 2013
    • 142
    [Misc] IRAV C9065
    Machine ran fine after initial setup. After installing options the machine generated an E025-0302 error code. According to canon the error code has something to do with the cyan toner hopper. After discovering that replacement of the entire hopper assembly is recommended with part# FM3-9977-000. I then discovered that said part# was discontinued. Preforming some high level research ( plus a phone call to cannon parts depot ) It was reviled that these parts must be ordered. FM1-C001-000, FM1-C002-000, FM1-C003-000,and FM1-C004-000 according to the nice lady from Canon parts. Now that the parts are in I have an issue. FM1-C001-000 and FM1-C003-000 are the entire CMY toner hopper assembly. While FM1-C002-000 and FM1-C004-000 are just the single color toner hoppers.
    Now I just need to know which assembly to use for a north American IRAC9065. FM1-C001-000, or FM1-C003-000? I will send the rest back
  • vigour
    • Aug 2010
    • 1038
    Re: IRAV C9065
    It depends on your serial no.
    coo3 is new style , it goes on serial numbers starting with Hxx.
    c001 on older machines.
    • vigour
      • Aug 2010
      • 1038
      Re: IRAV C9065
      I hope you have not read this yet.
      I think I wrote it backwards.
      Here is the Correct info for 9065 PRO
      Affected Machines are:
      FNE 00500-FNE 00647
      GNQ00500----GNQ00745
      GNQ01000----GNQ10336
      GNQ03000----GNQ30049
      Use FM1- C003 or FM1- C004 for the above machines.
      GNQ00746----GNQ09999
      GNQ10337----GNQ19999
      GNQ30050 or higher
      All HJX serial numbers
      Use FM1-C001 or FM1-C002 for this set
      Call in again tell them your serial number, and they should give you the correct parts.
      • mbcruzin
        • Aug 2013
        • 142
        Re: IRAV C9065
        Yeah I finally saw he tech pub tp13-135b. My unit was in group two. I finally got the machine back together. After a few issues related to me missing a plug or three all is well. Thanks for the help.
