Canon IR ADV C5051 Yellow leak
  • micboule
    Hi!
    I'd like to know if someone had this problem with C5051. Any solution for this?
  • spectraindo
    • May 2008
    • 313
    Re: Canon IR ADV C5051 Yellow leak
    It is the drum that leaks, it is common with these machines altough the manuals says it lasts 60.000 prints.
    Since the colour drums are the same, you can switch the Yellow drum with Magenta or Cyan.
    To make sure make a PG no 5 test print.
    • V-P
      • Apr 2011
      • 679
      my money is on the dev unit.
      try switching the drums to be sure...
