So I have this beast...squews on the 2nd side when duplexing from the DADF only.....the original service guy here has suffered long enough...hes changed the duplexer ...the whole fuser/ transfer assembly drawer...had the DADF apart as much as possible..messed with the settings...thank goodness for factory resets....so when you duplex it always squews the exact same amount/direction on the 2nd side every time and only from the DADF
Also will a J1 DADF and a Q1 DADF interchange on the same machine... the 7095 has a Q1 and I have a whole J1 so can I switch them for a test?
Thanks to all of you out there!!! Now what ye be sayin!!!
