instalationl lbp6200d for win 7 64bit
  • nokia88
    • Aug 2009
    • 72
    [Error Code] instalationl lbp6200d for win 7 64bit
    Hi,
    I've problem with installation canon Lasershot lbp6200 (brand-new machine) for win 7 64bit:
    PC can not config port (fail, code-28)
    Action:
    -try to uninstall divice & update driver software(usb controller/ Divice manager)
    -installation by add priter..
    -tried to download driver for win 7 64bit from canon.com
    *the problem can not solve...
    + i tried setup this canon lbp 6200d for an other PC (OS. windows xp), it's OK.
    + the PC (os= win 7 64bit) operating ok with an other printers (epson L110 and Fujixerox DC2060)
    Can you help me ???
    Tks.
  • teckat
    • 16083
    Re: instalationl lbp6200d for win 7 64bit
    [Windows 64bit] LBP6200d CAPT Printer Driver (R1.51 Ver.1.10)
    Setup instruction
    *Precaution When Using a USB Connection
    Disconnect the USB cable that connects the device and computer before installing the driver.
    Connect the USB cable after installing the driver.
    Driver and application software files have been compressed.
    The following instructions show you how to download the compressed files and decompress them.
    1. To download files, click the file link, select [Save], and specify the directory where you want to save the file.The download will start automatically.
    2. Downloaded files are saved in the specified folder in a self-extracting format (.exe format).
    3. Double-click the files to decompress them. A new folder will be created in the same folder.The new folder will have the same name as the compressed file.
    4. Double-click the decompressed Setup.exe file to start installation.
    File information
    • File name : LBP6200d_R151_V110_W64_uk_EN_1.exe
    • File version : R1.51V1.10
    • File language : English
    • File size : 13,628KB
    • teckat
      • 16083
      Printer Is Not Recognized Automatically (When Installing the Printer Driver)
      READ-----------The Printer Is Not Recognized Automatically (When Installing the Printer Driver)
      or-The Printer Is Not Recognized Automatically (When Installing the Printer Driver)-.pdf
