Canon IR 1025 CQ
  • Acme
    • Jan 2013
    • 155
    Canon IR 1025 CQ
    Ive got a few of these that after about 20k copies, get really light, almost like a halftone or its set on photo mode but its not. OEM toner is used in all of them, and the only way to get the density back is to put a new developer unit in it.
    Any Ideas?
  • northernlife
    • Sep 2011
    • 847
    Re: Canon IR 1025 CQ
    Is the coating on the dev extremely light? Are you running a full toner install when you change the dev? If you run a toner stir/install on the old dev does it come back a little bit at all?
    • Acme
      • Jan 2013
      • 155
      Yes the developer on the mag roller is very thin. I had no idea you had to run a toner stir when adding toner.
      Can you give me a heads up on how to run it?
      • northernlife
        • Sep 2011
        • 847
        Swear to god there's a toner stir on this model but I can't find it. you would usually just do it when you replace the dev. Still looking but I could be wrong, wouldn't be the first, nor the last time for that lol.
          • 16083
          no toner stir in this series
          how is image on DRUM SURFACE ?
          make sure toner saver is "OFF" in both locations
          PRINTER SETTINGS>
          PRINT QUALITY>TONER SAVER MODE OFF(*), ON
          COMMON SETTINGS>
          CHECK>Transfer Roller Bias Tab
