insert drum IRC 2880i
  • calle
    • Apr 2014
    • 6
    [Error Code] insert drum IRC 2880i
    Can some one provide me with the servicemanual and latest FW (+ procedure) for the Canon IRC 2880i? Insert drum message for all colours appears randomly with new drums, i suppose I have to replace the transfer belt as the drive couplers are ok.
    I have access to Samsung manuals for trade.
    Thx, Calle
  • vamoursly
    • Sep 2011
    • 273
    Re: insert drum IRC 2880i
    Check out this previous post, should sort you out;
    http://www.copytechnet.com/forums/ca...ert+black+drum
    V
    • calle
      • Apr 2014
      • 6
      Thx, I saw that post before and checked everything. It's just the SM, FW and SST I need
      Calle
      • canonbundy
        • Jun 2012
        • 607
        Calle
        Well, thank goodness for that - I thought you wanted something difficult ...................we can supply, no worries, it comes with free tickets to Disneyland & a $1000 voucher for a Vegas Casino too............................................WEL L, that's about what it cost us to find out how to do what you want to do .................for NOTHING!!!!
        • Nutstar
          • Mar 2011
          • 110
          not exactly the most helpful of posts.
          the insert drum issue can be a number of things, updating to the latest firmware is a possible fix as is cleaning the contacts.
          the latest firmware is 94.01
          latest edition of the service manual is published 2nd Feb 2008
          latest SST is version 4.72ek
          • calle
            • Apr 2014
            • 6
            I don't quite understand why you waste your time (and mine) on typing these words as they have no relevant info........
            Well, I'm just helping out a customer who's Canon dealer quit, it's not my core brand. I told this forum (as many are) is for helping each other in the same business?
            • jrgf67
              • Feb 2010
              • 37
              Greetings. You have to upgrade to the latest version Dcon
              • calle
                • Apr 2014
                • 6
                Whow great mate. Then I can sell the tickets because I don't like Disneyland and hate gambling.
                You have some relevant info for me to
                calle
                • calle
                  • Apr 2014
                  • 6
                  Thx for the info Nutstar, do you know where to get these? I'm helping out a customer who's dealer quit, it's not my core brand.
                  calle
                  • Nutstar
                    • Mar 2011
                    • 110
                    calle
                    sorry I can't give that stuff out, I get them directly from SIMS but that's the cannon engineer support site, if you don't have access to that then you'll need to contact a canon dealer or canon direct, no idea how you'd go about it from there really.
                    • canonbundy
                      • Jun 2012
                      • 607
                      It's like I said earlier!!!!
                      • calle
                        • Apr 2014
                        • 6
                        Bundy, I can't remember asking the Disney or Vegas representative for advice, so please don't waste my time interfering
                        calle
                        • teckat
                          • 16083
                          calle
                          Identifying a New/Old Drum Unit
                          This device does not have memory in the drum unit so, when a new drum is mounted, the drum life counter value stored in the printed needs to be reset.
                          The device detects old and new drum units, so that the counter can be reset.
                          The detection is performed by the DC controller CPU monitoring the fuse detection signal.
                          When the CPU detects that a new drum unit has been mounted, it outputs a fusing signal and blows the fuse on the drum unit. At the same time, the drum life counter resets to 0.
                          Do not replace drum units with new ones unnecessarily, in order to check function operations during service, etc. The device blows the drum fuse as soon as it detects a new drum unit and resets the drum life counter to 0.
                          Even if the old drum unit is replaced immediately, the drum life counter will increment as a new drum unit.
                          Service Mode:
                          COPIER > FUNCTION > INSTALL > AINR-OFF
                          Invalidates drum initialization that is performed when a new drum unit is installed. Also, the fuse is not blown, as it would usually be after drum initialization is completed.
                          This mode would be used to replace a drum unit temporarily in order to check image quality, for example when trying to trace the cause of a problem.
                          0: Initialization carried out for new unit. Fuse blown. (Default)
                          1: No initialization for new unit. Fuse not blown.
                          Further, this service mode should be set to [1] only when necessary for service. After the service is complete, the setting must always be returned to [0].
                          1---what is the firmware version ?/ especially DCon
                          To print out all of the Service Mode settings and firmware versions on the copier:
                          1. Enter Service Mode by hitting Additional Functions *key, #2 and #8 key together, then Additional Functions *key.
                          2. Select Copier.
                          3. Press Functions.
                          4. Hit MISC-P.
                          5. Select P-PRINT and hit OK.
                          6. A Copy Service Report will print out containing the Service Mode settings and Firmware Versions for the copier.
                          2---what was your inspection/checking procedures ?
                          3---the ITB UNIT on this series causes this false message & many more headache issues ? (age) (lock down) (dirty or damage connections)
                          4---is the M1 - the Drum / IT drive motor turning ?
