Canon ir4570 cyalander pro
  • mramlawi
    • Jul 2011
    • 838
    Dear all ,
    i have a canon ir4570 that the cylander of it collecting toner on the right side i wonder actually why ,i already changed cylander and after 4000k cylander made the same problem also when i saw the drum there was toner collection on the right side also photo (6)4.jpg
    Distinguished road makes you jewel in rough
  • northernlife
    • Sep 2011
    • 847
    Re: Canon ir4570 cyalander pro
    if the oil seals X71-9310-000 have been changed along with a new cylinder then I'd point at the blade FM2-0289-000 being out of alignment.
    • mramlawi
      • Jul 2011
      • 838
      thank you
      • spectraindo
        • May 2008
        • 313
        Check the position of the machine with a water level, is it level ?
        • mramlawi
          • Jul 2011
          • 838
          how 's that ?
          • spectraindo
            • May 2008
            • 313
            The floor on which the machine stands must be level, not tilted.
            A tilted floor will cause the toner to run to one side of the machine .
