Universel send can't send to Windows 8.1 via SMB
  • hsiangson87
    • Aug 2013
    • 8
    i am facing this problem,
    When i am using Windows 8, i can send by SMB, but i can't send after upgrade windows to Windows 8.1, show msg "Check the server"..
    I already check everything (firewall, anti-virus,etc...), setting all are done..
    What can i do...
  • northernlife
    • Sep 2011
    • 847
    Re: Universel send can't send to Windows 8.1 via SMB
    can you browse the share on another workstation (non windows 8) and read/write?
    • hsiangson87
      • Aug 2013
      • 8
      Yes, I try to use another workstation to view that, write that, it's work...
      • northernlife
        • Sep 2011
        • 847
        Can you browse via smb when you do a new send > file > browse on the canon? Can you see the shared share via the same procedure too?
        • hsiangson87
          • Aug 2013
          • 8
          Yes, everything just like normal setting.. same setting in Windows 8 and Windows 8.1, Windows 8 success to send, windows 8.1 show "Check the Server"
          • northernlife
            • Sep 2011
            • 847
            Do you get a report with a numerical code or does it not even try to scan at all?
            • northernlife
              • Sep 2011
              • 847
              Did some digging and found this bulletin
              When sending data using SMB to an SMB share an error occurs and data cannot be sent although you are able to browse the folder. The device will indication a #801 error and "check the server"
              Install the following patch and all should be well.
              Windows 8.1 and Windows Server 2012 R2 General Availability Update Rollup
              • hsiangson87
                • Aug 2013
                • 8
                Error Code #801..
                • hsiangson87
                  • Aug 2013
                  • 8
                  Already try to update and Auto Windows update, still not work..
                  • vamoursly
                    • Sep 2011
                    • 273
                    If you have done the window updates, that isolates that.
                    Check the DNS and possibilty WINS entries on the copier, is the gateway valid; some networks still use WINS, can you believe it
                    Check in the network settings of the network connection for the target computer, is it is set to public / home or office profile?
                    Check to ensure file and print sharing is enabled in advanced networking
                    If its on public it will close the firewall down, you need to change the profile to office preferably
                    My next step would be to reverify the login credentials, were is the account configured, on the local security database of the target computer or in active directory on a server?
                    I would physically login as the account configured on the copier onto another computer on the same subnet as the copier and see what effective permissions that gives you, can you browse to the share using the UNC path; \\computername\sharename - can you WRITE to the directory?
                    If that works you then know its an issue with the copiers SMB configuration, I would delete it and create a new one from scratch and test.
                    Good Luck win 8.1 works better than Win 8
                    Another cool add on is Windows 8 classic shell, google it and see if it will help your environment
                    V
