Canon imagepress c1 err please help!
  • mrban
    • Sep 2012
    • 25
    Canon imagepress c1 err please help me !
  • teckat
    • 16083
    Re: Canon imagepress c1 err please help!
    Check your transfer unit
    • mrban
      • Sep 2012
      • 25
      Can you show me more info ?
      • teckat
        • 16083
        Looks like a Developer Bias issue /check Developer Bias HVT Lead on Connector J416D
        what service did u do to printer before this issue or / was it like this from the start
        Remove the ITB assembly and inspect
        • mrban
          • Sep 2012
          • 25
          Thanks Teckat, after print 500 envelope 12x22 cm, i saw the page lost yelow color, and err e020-186. Then i restart printer and test a page, it too bad! I will check developer bias. Thanks again!
          • teckat
            • 16083
            xx86= Patch image sampling (center) error 2
            DISPLAY>DENS>DENS-S-Y/M/C/K (patch image measurement value) - DISPLAY>P-SENS-P (Drum background measurement value)
            </= 30.
            1. Execute the test print (TEST>PG TYPE=5&96, THRU=1), check the evenness of image -> check the Developing Motor.
            2. If the value of DISPLAY>DPOT>PT-LPW-Y/M/C/K is more than 250,
            (1) Clean the Dust-proof Glass and check.
            (2) Replace the drum.
            (3) Replace the Laser Scanner Unit/clean inside.
            remember to also>>>>>>>>>>>>
            CLEAN PATCH SENSOR--------------------------------------------------------
            1. After cleaning the Patch Sensor, execute FUNCTION>MISC-P>PT-LPADJ.
            Select DISPLAY>DENS>PCH-LED2, and check the value of PCH-LED2 (1).
            2. After removing the Patch Sensor Shutter,execute FUNCTION>MISC-P>PT-LPADJ.
            Select DISPLAY>DENS>PCH-LED2, and check the value of PCH-LED2 (2).
            3. If (1) is more than 240 and (2) is between 80 and 240, replace the shutter and solenoid. Then, execute PT-LPADJ again.
            If the value is between 80 and 240, complete the remedy.
            If not, go to step 4.
            4. After replacing the Patch Sensor, execute PT-LPADJ. If the value is between 80 and 240, complete the remedy.
            • mrban
              • Sep 2012
              • 25
              Thanks Teckat , my printer is worked !
              • teckat
                • 16083
