Canon IR C3220 Strange Print Across Every Page
  • Jazzy
    We have a IR C3200 with a imagePASS-C1 and it just started printing a strange scribble across the center of every page, even when we just try to make a copy. I've attached a couple of pics so you can see what I'm talking about. This page was printed right from the copier from the color calibration utility.
    Please any help would be great.
    Jeff
  • canonbundy
    • Jun 2012
    • 607
    Re: Canon IR C3220 Strange Print Across Every Page
    [ATTACH=CONFIG]24805[/ATTACH][ATTACH=CONFIG]24806[/ATTACH][ATTACH=CONFIG]24807[/ATTACH]
    Jeff
    Looks like electrical interference from Dev or Drum Unit - try doing half tone Prints from each colour, this may assist.
    • teckat
      • 16083
      Jeff
      something is arching against the Transfer Belt-------
      • Venom
        Technical/IT Support
        • Nov 2009
        • 765
        Looks like bent mylar or somehing contacting transfer belt
        IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
        • Jazzy
          I want to thank everyone for there help, after checking components everyone said to check, I found that the Black Drum Unit was the cause. I replaced the drum unit and it work great.
          Thank You All for your help!!
          Jeff
