Hola a todos, la imagepress C6000 indica codigo E998-010-05. Cada momento, cuando la enciendo aparece el codigo constantemente.
Alguien tiene idea donde puede estar el problema?
Bit 15 | Drum Driver Pcb ( Y ) | Bit 7 | Secondary Fixing Driver Pcb | |
Bit 14 | Drum Driver Pcb ( M ) | Bit 6 | Registration Patch Sensor Driver Pcb | |
Bit 13 | Drum Driver Pcb ( C ) | Bit 5 | Hot Driver PCB ( Hopper ) | |
Bit 12 | Drum Driver Pcb ( B ) | Bit 4 | Deck Control Pcb | |
Bit 11 | Process Unit Driver Pcb ( Y ) | Bit 3 | Primary Fixing Driver PCB | |
Bit 10 | Process Unit Driver Pcb ( M ) | Bit 2 | ITB Driver Pcb | |
Bit 9 | Process Unit Driver Pcb ( C ) | Bit 1 | Registration Feed Driver Pcb | |
Bit 8 | Process Unit Driver Pcb ( B ) | Bit 0 | Not Used |
