Canon IR C2880 jamming at fuser
  • jonbonse
    • Jun 2009
    • 737
    Hi all
    Can anyone help with a Canon IR C2880 which jams at the fuser?
    The paper comes out of the fuser approx 2" fine then jams and the remainder of the paper buckles up. . . The first 2" that exits the fuser is not crumpled or damaged.
    It has just had a lower right hand side door mod and both cassette feed rollers.
    I even installed a known working fuser.
    Regards
  • vamoursly
    • Sep 2011
    • 273
    Re: Canon IR C2880 jamming at fuser
    So jamming from all trays, side door modified done, no 003 errors and known good fuser put in.
    Is it jamming on all prints, 1 sided or double sided;
    I would direct my attention to the 3 way delivery, located just above the side door, maybe a flapper is not functioning correctly, actuator is blown, which can be tested in service mode.
    V
    • canonbundy
      • Jun 2012
      • 607
      Originally posted by jonbonse
      Hi all
      Regards
      Even with a "known working fuser" - I would suspect the Orange Delivery Roller in the Fuser Cover is not turning freely, ie the Bushings & Shaft wear & will bind slowing the transport of the paper through the Fuser - test the movement of the roller with your finger - try a light silicon oil on the bushings.
      • Alex ahir
        • May 2012
        • 125
        look like flapper on the 3way unit is now actuating properly. check that
