canon ir 5070 fax board
  • Jerrygbs
    • Dec 2008
    • 194
    I have put 2 different fax boards in this ir 5070 both only receive 1st page of a multi-page fax. I can put a normal fax on the line and it works great. Am I missing an up grade ? I have never had to change anything on the copier when adding a fax. The machine doesn't give an error and the sending machine finally shows no good in the fax log.
  • Alex ahir
    • May 2012
    • 125
    Re: canon ir 5070 fax board
    Enter service mode, fax, clear and select NCU.
    • teckat
      • 16083
      so this is a RX issue only ?
      TX is ok ?
      U may need to do a MMI CLEAR on this Printer
      Clearing MMI and the Main Controller will delete some User, Service, and Network settings. Print out the User Data Lists, P-Print, Configuration Pages, and any other reports that contain valuable settings./ for input later
