c3220 problem
  • pc123321
    • Dec 2012
    • 103
    c3220 problem
    this is canon c3220
    here is photo printed
    any advice or recommend are welcome
    thanks
  • teckat
    • 16081
    Re: c3220 problem
    Originally posted by pc123321
    this is canon c3220
    thanks
    what have u done so far ? if anything ?
    have u checked your external secondary transfer roller ?
    post a PG10 test print
    i would pull out the ITB>INSPECT>remove ITB SHEET>CLEAN UNDERSIDE
    • Rvale
      • 83
      Re: c3220 problem
      on the first copy you have two possibilities, charging and cleaning, on the last three drum itself, so the most useful test would be changing the whole IU.
      • pc123321
        • Dec 2012
        • 103
        Re: c3220 problem
        problem find itb belt left side handle drive roller shaft bent
