Canon ir 2200 dark copies
  • stevee104
    • Mar 2007
    • 214
    toner was change with oem gpr-6 and copies where fine before change of toner, i have a service manual and before i go and do some changes that i will regret is the toner bad or a drum issue, copy count is 155000. I don't work on canons much but it looks like i need to vacum the toner out and try another one. i have a sample attached.
  • kuby
    • Oct 2007
    • 1408
    Re: Canon ir 2200 dark copies
    How many copies on the drum? Good for between 50K and 80K. Sure looks like a toner dusting issue to me. Check the seals on the developing unit, vac out, clean the slit glass and inspect to make sure that toner is not in the laser unit.
    • stevee104
      • Mar 2007
      • 214
      drum unit has 18k on it, does canon toner go bad after a year or 2 .
      • Canuck
        Tech Specialist
        • 1713
        I see drum lines near the top...this drum has more than 18k on it by the looks of it...swap the drum and go from there.
        • Rvale
          • 83
          • Rvale
            • 83
            100% right, the drum have way more than that or the toner really damaged it, black lines on top and small on bottom and the white line on the middle says charge roller as well, or maybe spacersa on the mag roller are quite old, shade issues point on developing and not drum, so both. sorry for that.
            • stevee104
              • Mar 2007
              • 214
              Replaced drum unit, vacuum out old toner and not one change. Can go in the adjust mode in service manual and change the value of DE-offset
              and the copies improve 100% but after about 15 copies it throws the old 064-0000 code which is charge, transfer, or dv bias problem. With that said i don't know what else to do because have no other boards or parts to swap out now, and don't think it is the dv unit itself but i don't have one to try.
              • Simons
                • Jun 2008
                • 490
                I would like to see a compare to printing. Looks like toner on wires around reader controller can make this background but less severe on 4570. For sure go back to door specs. Good you tried another drum. Developer ??? machine may have taken a bad surge. I have seen surges kill this model. Hard to bring back on the one i tried and yes I had a parts machine.
                • brother
                  vacum the toner out and replace a new toner
