I have a Canon ir3300i that has a black screen, the buttons all work as you can still use it you just can't see the screen. We've replaced the entire control panel and still have the same problem.
ir3300i display black
Tags: None
Re: ir3300i display black
1-check connectors on Composite Power Supply.
2-DC Controller > FLASH DIMM
3-check Memory
4-Boot DIMM**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Embarrassed to say it was the lcd screen, evidentally the 2nd control panel we tried was bad as well.Comment
