canon c6000 imagepress erorr code
  • manhiemco
    we have error code E000001-0151-05
    WE CHANGED SOME PARTS OF PRIMARY FIXING UNIT BUT WE COULDNT FIX THIS PROBLEM.
    PLEASE HELP US.
    • 16083
    Re: canon c6000 imagepress erorr code
    PLEASE HELP US.
    0x51/ x=1: Primary fixing = 2: Secondary fixing
    0151
    Error: software detection of abnormally rising temperature at fixing roller sub thermistor
    When the fixing roller sub thermistor detects the temperature that exceeds the specified value (primary: 210 deg C, secondary: 230 deg C) for 1 sec continuously--
    Fixing roller main thermistor:
    THM301(primary fixing),
    THM306(secondary fixing)
    Fixing roller sub thermistor:
    THM304(primary fixing),
    THM309(secondary fixing)
    Fixing external driver PCB: UN304(primary
    fixing), UN305(secondary fixing)
    Fixing heater driver PCB: UN306(primary
    fixing), UN307(secondary fixing)
    Fixing duplexing feed driver PCB: UN311
    DC controller PCB 1-2: UN124
    1. Check for any caught harnesses. => Replace them if necessary.
    - fixing roller sub thermistor
    - between the fixing roller sub thermistor and the fixing external driver PCB
    - between the fixing external driver PCB and the fixing duplexing feed driver PCB
    - between the fixing duplexing feed driver PCB and the DC controller PCB 1-2
    2. Check that the fixing roller sub thermistor is clean and properly installed. => Clean and reinstall it if necessary.
    3. Replace the following parts if necessary.
    - fixing roller main thermistor
    - fixing heater driver PCB
    - fixing external driver PCB
    - fixing duplexing feed driver PCB
    - DC controller PCB 1-2
    Does the machine know if the doors are open or closed/ or if Fuser is in Printer
    if so>>>>>>>>>>>
    Pull out the Drive Reverse / External Delivery unit.
    Clear out code and shut machine off.
    Turn machine back on with this unit left out and doors open.
    Machine will tell you to close the doors.
    if yes
    replace the Reverse / External Delivery PCB (FM2-7701-000)
