c3220 secondary transfe outside roller has a film of toner magenta
  • pc123321
    • Dec 2012
    • 103
    because secondary transfer roller outside has a film of toner , so on the printout paper can see the magenta toner
    imaging unit of drum upstream brush or downstream brush problem ?
    or something else any advice are welcome thanks
  • pc123321
    • Dec 2012
    • 103
    Re: c3220 secondary transfe outside roller has a film of toner magenta
    this is the secondar transfer external roller under the ibt belt
    • teckat
      • 16084
      where do u see M toner on paper> top or bottom of sheet ?
      do u see M Background on copy >
      check M Drum surface for any coating left on it after copying !!!!!
      • pc123321
        • Dec 2012
        • 103
        why always magenta drum has the problem ?
        i disassembly the magenta drum i found that upper brush and downbrush
        the toner left on the brush is uneven , near side me is much more magenta toner than far side of brush,that is why magenta toner left on paper (background)
