ir5870c problem with black lines
  • Apach
    • 157
    Hello,
    I just changed Black developing assembly, Belt, Cleaner assembly and primary corona but I still have black lines like on photos
    What part can caused this problem ?
    There is no stupid question, just stupid answer
  • Nutstar
    • Mar 2011
    • 110
    Re: ir5870c problem with black lines
    the drum unit itself
    • Apach
      • 157
      Drum is OK and have less then 400k copys. Tomorrow I'll disassemble all the parts, down to the last screw
      • Nutstar
        • Mar 2011
        • 110
        how's the fixing assembly?
        • kuby
          • Oct 2007
          • 1396
          Did you just check the coronas or change them? I would change them.
          • Canuck
            Tech Specialist
            • 1713
            Looks like arcing...rewire the pre-transfer corona(since you already did primary)
            • Apach
              • 157
              I'm replaced both corona's. Same results. Any idea?
