Adding print to ir3530
  • repeatcopiers
    • Sep 2008
    • 591
    Can someone tell me what is involved in adding print to a ir3530. Had a customer buy one and wanted copy only, so I believe the wholesaler removed the print or at least the expansion board w/ethernet port. Now the customer has changed their mind and wants print added. Is there a way to tell if the print software is loaded and all I need is the kit? The wholesaler is telling me I need to bring the copier back in to have the print added and I would rather buy the kit from them and do it in the field.
  • Brian8506
    • 1664
    Re: Adding print to ir3530
    Addl func/2 an 8 at same time/ addl func/copier/display/version. Scroll to see if bootrom is C or N. If it's C you need print kit. Bootrom, hard drive, expansion board
    • teckat
      • 16083
      U have a HDD Model or ROM Type (has no HDD -copy only)
      if u can't print a P PRINT> u have a ROM Type
      Install a Multi-PDL Printer Kit-E1 to have printing functionality.
      The machine is capable of printing UFRII, PCL and PS with the print kit installed.
      (Kit has "N" Boot Rom ) & U need to install N/W ScanGear software
      why would the pull the NIC CARD ( Kit has no NIC CARD)
      Brian said it> u need the "N" Boot ROM >HDD & Nic Board
