hi all...I have a irac2225 that throws error e000749-006..just before code comes up it says on screen storing system information??...can still scan but cannot copy...have loaded all firmware ...??
image runner advanced c2225
Tags: None
Re: image runner advanced c2225
E749 0006 00Restart direction due to configuration change.
The option such as the Finisher and ADF was installed or removed when all of following conditions were met and the machine configuration is changed when the main power switch is turned ON.
- Settings/Registration > Preferences > Timer/Energy Settings
> Quick Start-up at Power-on > ON
- The Main Power Switch is turned OFF
- The power plug of the machine is connected to the output
Remedy = It is recovered by turning OFF and then ON the main power.
CAUTION
This machine provides power to some PCBs even when in the main power OFF status.
The power supply is not completely OFF by just turning OFF the main power switch and therefore, the machine is unable to
detect a configuration change.
When disconnecting and then connecting a connector, always disconnect the power plug.
Refer to the Service Manual > Chapter 2 > External and Controls > Quick Start-up for details.
In addition, quick start-up is not performed under the following conditions.
At first start-up after the AC Power Plug is connected to the outlet
Under the following conditions (settings), the machine always starts up normally (even quick start-up is ON).
When any of the following devices is connected.When any of the following network settings is set to "ON".FAXMEAP
During execution of MEAP application which prohibits moving to Deep Sleep
A scheduled processing is reserved on MEAP.
Job ProcessingOthers**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
machine has been in use for 6 months at customers and no new add ons fitted..i am waiting on reply from canon at moment...can log in through rui...but error still occurs when copy screen on ....can still scan...Comment
Spoke to canon have been advised to replaced ac driver pcb...will post resultComment
Canon tech support/ they read from manual or search for similar call center notes on issue
Call CENTER
E749
Booting instruction due to change in hardware configuration
There is a change in configuration that requires turning OFF and then ON the power
Solution :
The symptom to recovering is to turn OFF and then ON the power.
If this solution does not resolve the problem, please dispatch a local technician with the Smart Dispatch Information listed below.
Smart Dispatch Information :
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Only had 1 reported case with same sub code (apparently)....i have done box check on machine everything coming back ok....i thought main cont 1..but phoned canon for advise and that was answer..ac driver has been ordered so will fit when comes in..Comment
I had this happen once on a brand new C2225.
Called Canon, they told me to set the power saver usage to high instead of low. I cleared error in service and flashed the F/W with USB key.
Problem solved.
I think there was some weird problem with the firmware where the low power sleep didn't fire a remote signal to the reader controller when it came back, but instead of displaying a reader controller error, it gives you the config error.Comment
Thanks to all for replying to post....ac driver pcb changed today and cured err..whilst on site changed power saving from low to high....thanks againComment
Great___now the Almighty Wizards in Canon should post it under the phone support link for this model, did u report back to Canon on success of part ?**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
